cancel
Job type :
Zip Code :
community forums
comments
Modern Electric Fireplace Styles: A Guide
A modern electric fireplaceis a great way to add warmth and ambiance to any room. But if you're unsure what style is right for you, here are a few options to consider.
Corner Styles
As long as you have access to an electrical outlet, you can install your electric fireplace just about anywhere. A popular choice is the corner of a room, and there are styles designed and shaped to fit snugly into most corners. This option saves on wall space, and corner space is often underutilized. You can find these styles of fireplace designs in a wide varieties ranging from European high fashion to traditional décor.
Recessed
If you don’t mind cutting in to your walls and you want a high-end look, try looking at some of the flush, or recessed fireplace styles. Since you don’t need a chimney to vent smoke, this can be very easy to place to open up options on where to set your fireplace. These designs are very sleek with clean lines and are easy to decorate around.
Metro or Urban Styles
Along with traditional looks and models, there are many new and more modern-looking styles of electric fireplace available. Metro and urban styles generally combine clean lines with funky elements such as bright colors or mirrored backgrounds to change up the look of a fireplace. Costs are also comparable to more traditional fireplace styles.
member comments
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
How to Build a Shoe Storage Bench
sponsored articles of the day
