Login Error
Close
Modern Kitchen Remodel Design to Consider
by DoItYourself Staff
If you've decided to rework and redesign your kitchen for a more modern appearance, the next step is to pick between the hundreds of different types of kitchen remodel designs that you have as inspiration. While it's unlikely that you'll use any of these designs wholesale, you may nonetheless find some sort of guidance or inspiration in them, and many people combine different elements of designs to create a unique kitchen remodeling project that suits their own budget, needs and style. Read on for a few interesting modern kitchen remodeling designs to consider.
Islands
If you have sufficient space in your kitchen, consider installing an island to set the space apart from other areas in your home. You may even consider sacrificing some of the main counter space in order to put in an island. An island doubles as both a food preparation space and as a sort of table where people can gather around. Some people opt to put an oven and stovetop in the island, while others include a sink on their island. Still others use just a standard flat surface as an additional countertop space where people can gather around as a central focus point of the room.
Track Lighting
For a change from the traditional lighting in your home, consider using special track lighting for the kitchen. Track lighting provides both an excellent source of atmosphere in the kitchen, as it can be tailored to light up different parts of the room specifically, and a distinctive and modern appearance.
Counters
One of the best ways that you can change the appearance of your kitchen is by altering the countertops. Even if you don't plan to adjust the size and shape of the countertops in your kitchen, you can dramatically alter the appearance of the space by using a new material for the countertops. Consider the wide array of materials that are available; engineered stone, granite of different colors, laminates, woods and more. The exact type that you'll choose will be partially dependent upon your budget and also dependent upon your overall aesthetic. A countertop remodeling can be one of the easiest ways to improve and change the look and feel of your kitchen space.
Skylight
If your kitchen doesn't get a good deal of natural light from the windows, you may wish to consider installing a skylight as you plan your remodeling project. Skylights are a fantastic way of increasing the natural light in a space, which makes that room seem warmer and more inviting. This is also an untraditional method of revamping or redesigning a kitchen space, so it is sure to make your room stand apart from others in your area. Skylights come in a variety of styles, shapes and designs, giving you even more flexibility over the final appearance of your kitchen.
For more ideas on how to redesign your kitchen space, consult with an interior designer or visit a home improvement store. You can also look to kitchens in your friend's homes for ideas.
 forum activity
