cancel
Job type :
Zip Code :
community forums
comments
Modular Office Furniture Placement Ideas
Modular office furniture gives you lots of choices about how to arrange an office. Since modular office furniture is made to be flexible and easy to fit together, it’s simple to arrange an office so that you have maximum room efficiency. Still, good furniture arrangement principles should be used when arranging modular office furniture.
Think of the Room’s Flow
Arrange the modular units in clusters to use the space most efficiently. Although you can purchase furniture with a cubicle feel, it is also possible to find office furniture that is open and more welcoming, but still comes in modular units that are easy to add to or remove from the group.
Try to have the desks face other workers on one side, but offer some privacy on the other. Grouping modular work spaces together is the most efficient way of arranging office furniture, but be sure to leave open pathways to the common work areas like conference rooms, break rooms, and copy machines.
Use the Exterior Walls
If you have to wander through the modular office furniture as you walk through a room, you should rearrange. If the furniture clusters are mostly around the edges so that walking through the room is easier, it will be a more relaxed and less tense atmosphere.
You can also put things like a water cooler or copy machine in a central area so that the eye notices it first upon entering the room.  Seeing this, instead of a cluster of desks, can evoke a calmer feeling.
Individual Offices
Modular office furniture also comes in groups for individual offices as well. It’s simple to add vertical files, desks, credenzas, and tables when you start with a modular system.
member comments
Related Articles
Patio Furniture: Tables for All Seasons
Patio furniture tables come in materials and styles to suit all outdoor entertaining and living... read more
The History of Gothic Furniture
Gothic furniture is experiencing a revival of interest with interior designers and consumers... read more
Metal Patio Furniture Buying Guide: Steel, Iron or Aluminum?
Whether made of steel, iron or aluminum, metal patio furniture is designed to withstand harsh... read more
articles we like
Corian Countertop
A corian countertop is an easy to care for solid surface countertop that looks like... read more
Too Much Room? Make It Look Full Without Spending Too MuchToo Much Room? Make It Look Full Without Spending Too Much
How to decorate a large room without spending too much money... read more
Look younger now without risky, painful surgeryLook younger now without risky, painful surgery
If you could get the same results of a surgical face lift safely and naturally... read more
sponsored articles of the day
diy centers
