Login Error
Close
Monorail Track Lighting Basics Explained
by DoItYourself Staff
Monorail track lighting can be added to any home or business. It is a great way to light up your business or home in a classy, yet modern way. There are several different things that you should understand about this type of lighting as it is quite different than your average track lighting job. Remember, the more that you know and understand about what monorail track lighting, the better off you will be when choosing it for your home.
What It Is
Monorail track lighting is a type of track lighting that has a track that can be moved in several different ways. This track can be custom made to go around any area that you want to be lit up. It can go along with any contour of any area. No matter how difficult the shape, you will be able to get it made to go along with it. It is a beautiful and an especially unique way to be able to light up any room of your home or your business.
Benefits
One of the many benefits to this type of lighting is the fact that it is very flexible. You will be able to change the tracks yourself so that you can change the shape or location of the fixture at any time. You will also find that with the ability to have them custom made, you will be able to make sure that your monorail track lighting is truly one of a kind. To add to its versatility, it can also be prewired or come with its own fixture. Whichever you prefer, it can be done. A pre wired system is going to come with low voltage and the transformer itself will go off into its own remote location out of sight. However, a fixture is not something that is difficult to obtain either.
What to Use It for
You will find that the possibilities are endless as far as the uses for monorail track lighting goes. There are several different things that you will be able to do with it. If you have a lot of art work or collect it, you will be able to have a track that will illuminate all of the pieces of work that you wish to display. You can also use it for a kitchen or a bathroom, basically any room that you wish to have a lot of lighting in. Track lighting will be able to provide you with a straight line of lights that can go along any area. However, monorail track lighting can go along curves, corners and fans or anything else that you may have that you wish to go around. You will also be able to use it to make shapes unique to your décor or your own personal taste. This type of lighting is used in businesses as well as in homes. It is a great conversation piece and can help you as well as your home get noticed and remembered.
 forum activity
