Mortarless Brick Veneer Siding: Pros and Cons
Using mortarless brick veneer siding on your home is one of the practical and cost efficient ways of improving your home. If you are planning to do some home improvements in the next few months, you might want to consider using this material for your sidings. To help you decide as to whether or not mortarless brick veneer siding is right for you, here are some of its pros and cons.
Pros
Mortarless brick veneer sidings come in different designs, colors and sizes so you can easily find something that fits into the overall layout of your home. Most hardware stores, both online and offline, offer wide choices of brick veneer sidings so all you need to do is choose which ones fit into your home. Also, this type of construction material is less expensive than the traditional brick sidings so you can actually save some money if you use mortarless brick veneer sidings in your home.
Aside having aesthetic and economic advantages, mortarless brick veneer sidings are easy to install so you do not need to hire a professional to do the job for you.
Cons
Since mortarless brick veneer sidings are meant to adhere to your walls, these materials may be dislodged when subjected to strong vibrations. If your home is near the railroad or if you live in an earthquake prone area, this type of sidings may not work well for you.
