Login Error
Close
Multi-Fuel Pellet Stove Advantages
by DoItYourself Staff
If you are considering a pellet stove for your home, you should consider the numerous advantages to choosing a multi-fuel pellet stove. While pellet stoves have many positive features, they are equaled or surpassed in every way by multi-fuel pellet stoves. You should strongly consider purchasing a multi-fuel pellet stove, should you have the chance to do so. Multi-fuel pellet stoves can do everything ordinary pellet stoves can do, and then more. What follows should make the wide variety of advantages that multi-fuel pellet stoves have over their standard counterparts clear.
Cost
Multi-fuel pellet stoves can save you a great deal of money in the long run. For one thing, a multi-fuel pellet stove has the advantage of being able to use multiple kinds of fuel. Given the volatility of the prices of different types of fuel, this is a significant advantage. If you had a fuel pellet stove that only accepted one variety of fuel, and the price of that fuel skyrocketed, you would be out of luck. With a multi-fuel pellet stove, you will never be stuck purchasing one overpriced variety of fuel.
Additionally, the types of fuel  that multi-fuel pellet stoves use tend to be cheaper than fossil fuels. Corn pellets, for example, are one of the cheapest varieties of fuel.
Reliability
Multi-fuel pellet stoves are easy to use and reliable. This is because running out of one type of fuel is not a problem because you have the option to switch. In fact, there are many things that would normally be considered waste products — for example, sawdust is one, but there are many others. Having the option to burn many types of fuel reduces the chance that you will ever have trouble finding something to burn.
Efficiency
Multi-fuel pellet stoves are extremely energy efficient. They can use almost all of the energy in any given fuel, to the point that they barely give off any waste material, at least in comparison to other solid fuel burning stoves. They are so efficient that they do not require a chimney to give off smoke — only a vent.
Additionally, they burn enough of the fuel that they use that they rarely need to be opened up and cleaned out. The lack of a chimney and a need for regular cleanings means that multi-fuel pellet stoves are easy to install and operate. Because they do not need chimneys to function normally, they can be installed in any home with a minimum of modification.
Ease of Use
Multi-fuel pellet stoves are straightforward and easy to use. Simply insert your fuel of choice — almost any organic matter that can fit through the front will do — and start it up. The versatile and efficient nature of a multi-fuel pellet stove makes it easy to install and use. The simple and limited ventilation needs of multi-fuel pellet stoves mean they can be installed and used anywhere.
 forum activity
