Login Error
Close
Octagon Windows: Pros and Cons
by DoItYourself Staff
Installing octagon windows has become a popular trend in the housing industry. While octagon windows can present you with some benefits, they are also subject to a few drawbacks. Here are some of the pros and cons of using octagon windows in your home.
Pros
  • Visually interesting- The fact that the windows are shaped like an octagon makes them visually interesting. When you are tired of the normal rectangular windows that you see everywhere, octagon windows gives you something new to look at.
  • Versatile- Octagon windows are not subject to one type of house or decorating style. They are a very versatile window that can be used in a number of different applications successfully.
Cons
  • Reduced light- With an octagon window, you will not be able to achieve the same amount of light coming in as you would with a rectangular window. The corners are basically cut off by the octagon shape and therefore, this blocks out some light.
  • Difficult to cover- The majority of window coverings out there are designed to fit over rectangular windows. When you try to cover an octagon window with a window covering that was meant for a rectangular shape, it might not look good. You will have your work cut out for you trying to cover them properly.
 forum activity
