Login Error
Close
Oil Boiler vs Gas Boiler
by DoItYourself Staff
If you’re having trouble deciding between installing an oil boiler or a gas boiler in the house and cannot make a final pick, there are a number of factors to take into consideration before you make a choice. Any home appliance to be installed has to be chosen with care. Ensure that it is compatible with a number of other gadgets, systems and devices working within the house, and also make sure that external factors such as weather conditions, local supply, and the residential foundation and so on are compatible with the choice in mind. Ranging from the convenience offered in using either type to the different maintenance routines, there are a number of considerations to ponder before actually making a call.
Factor 1: Availability of Raw Material
The availability of the raw material is an important factor in choosing the type of boiler you wish to install in the house. Many places do not have provisions for natural gas, and if the community does not have the requisite distribution channels installed, installing a gas boiler is ill recommended. In such cases, it makes more sense to use an oil boiler.
Factor 2: Maintenance and Repair
One has to take into consideration the amount of time and energy one can put into the general upkeep and time-to-time repairs of the boiler installed in the house. In most cases, it has been found that oil boilers are not only more complex systems but are also much more expensive to repair. In the case of large oil tanks, one usually also needs provisions for on-site storage options. If there is a leak and spill with a large oil tank, the damage caused can be very extensive, and the cleanup and repairs can prove to be exorbitant. In this context, gas boilers are easier and less expensive to take care of. Gas boilers usually contain treatment to help prevent the buildup of impurities that otherwise lead to scaling and corrosion; this can be particularly helpful in an area with hard water.
Factor 3: Running Costs Involved
Running costs are one of the first determinants of any home appliance choice. The expenses incurred when using either No. 2 fuel oil or natural gas come to more or less the same amount. The availability of the material and region-specific codes might cause minor variations in the overhead costs, but the price per unit used is usually in the same range. Running costs are determined more by the amount of the material used and less by the per unit cost; hence, the efficiency and productivity of the fuel itself are also essential in determining the expenses. One can also augment the functionality by using effective insulation techniques in the house.
Factor 4: Ease of Use
The convenience offered in using a specific kind of boiler is also an influential factor in determining its usability. Oil that is used for home heating purposes is usually supplied by private companies straight to the homes of customers. A storage tank is usually built on the residential grounds, and the oil is sent directly to the same. Homeowners usually set up a system of deliveries weekly or at any intervals convenient to them to have the oil supplied to the house. The downfall of this system is that if one suddenly runs out of oil without prior notice, it can mean having to ask for emergency deliveries and support services. Natural gas, by contrast, is sent straight to the house, and its consumption is calculated by the local authority.
 forum activity
