Oil Stain Remover
Oil stain remover is called for any time greasy, oily substances come into contact with surfaces that are inclined to absorb them. Clothing, carpeting and other fabrics are particularly susceptible to damage caused by stains. When oil stain remover is used quickly, it can prevent damage from becoming permanent.
Household oil stain remover ingredients
Most households are ready stocked with ingredients that can double for oil stain remover. When these everyday ingredients are used on food-based grease and other oil stains, they can lessen or eliminate damage:
- Absorbing agents – Ingredients like cornstarch, salt or talc powder can be poured onto oil spots to start the process of cleaning. This step is particularly important when oil has not dried. These oil stain remover ingredients will lessen the damage and make cleanup easier.
- Degreasing agents – Basic dish soap can be used as an oil stain remover.
- Lighter fluid – Non-butane lighter fluids can also be used for cutting grease and lifting oil stains.
Steps involved in using an oil stain remover
When oil stains are a problem, it is important to first blot up as much of the stain as possible. Use an absorbing agent as an oil stain remover. Once dry or mostly dry, shake out or vacuum. If stains persist, try a degreasing agent and water to lift oil and prevent a stain from becoming permanent.
