One Way to Recharge a Dead Car Battery
what you'll need
- Your car
- Pair of battery clamps
- Battery charger
- Basic hand tools
The dead battery of a car can be a very difficult problem to solve. It may also take a long time and cost you money because you need to call a tow truck and you will need to buy a new battery as well. But you can solve the problem yourself by recharging the battery and you do not have to pay for the roadside service.
You need the basic hand tools if you are going to remove the battery from the car. You may not need to remove the car battery but keep the tools with you just in case. Remember that the battery is the supplier and storage box for the power needed by the car to operate properly.
Step 1 – Drive Your Car
If you suspect that your car's battery needs recharging, consider using your own car to recharge it. While driving we would be charging our car's battery by means of its alternator which produces electricity while the car is running.A 30 minute drive should produce enough electricity to recharge your battery.
Step 2 - Jump Start Your Car
Another option to consider is to jump start your car with the help of someone else's car. Bring the two cars close to each other in such a way that you are able to attach your black and red clamps to each of the cars' battery. While making sure that each car is switched off and not touching each other, clamp one side of your red clamp onto the positive terminal of your friend's car and the other end to your car's positive terminal. Next clamp one side of the black clamps onto the negative terminal of your friend's car but the other end attach it to an untreated metal part of your car while making sure that the cables do not touch each other. What you have to do now is to start your friend's car and leave it running for some time since in this way it will be charging your car's battery. When ready remove all cables and try starting your car.
Step 3 - Use a Battery Charger
If the above methods do not work then you need a battery charger to revive the dead battery of your car. You may give your battery a fast charge, but it is recommended that you give the battery a slow recharge, because car batteries have the tendency to have a more powerful charge with a slow recharge.
Open the car’s hood and find the battery. Most batteries can be found in the front and have their terminals located on the top. Clean the terminals if you find that the terminals are dirty. Check the alligator clamps and see if they fit onto the battery. Remove the battery if the alligator clamps do not fit the battery.
Step 4 – Recharging the Battery
After you have cleaned the battery, put it on a wooden bench. Keep in mind that you must never put the battery on concrete. If you see that the terminals are located on the side of the battery, you do not have to panic. Many auto parts shops and stores sell screw-in adapters. Make sure to turn the charger off before you plug it in. Connect the positive and negative terminals to the positive and negative leads respectively, and adjust the charger on a low amp setting.
Most battery chargers shut off automatically when the recharge is complete. If your charger does not shut off automatically, read the manufacturer’s directions and instructions to turn off the charger manually after a specific period of time.
Step 5 – Reinstalling the Battery
Once you have completely charged the battery, you can now install it back into the car if you had to remove it. Make sure that you do not leave any adapters connected to the battery when you place it back into the car. Remember to connect the positive and negative terminals to the positive and negative leads respectively.
Be very careful and do not cross the leads because you may cause the main fuse to blow and the battery may explode. Start your car and see whether it starts or not. If there is a power failure or there is no power at all, then you should replace the battery with a new one.
