Login Error
Close
Organic Cleaning for the Interior Home
by DoItYourself Staff
Organic cleaning is not only beneficial to the environment, but it is also easy on the income. Cleaning the interior of your home is easy and cost-effective with organic cleaning methods any day of the week.
What Is Organic Cleaning
Organic cleaning is the simple act of utilizing ordinary, safe, every day natural products often found in the home to clean its surroundings. For example, many organic cleaning items can be found in your own kitchen pantry such as baking soda, vinegar and club soda to start. Combine these products with a little bit of elbow grease on your part, and your home will be sparkling soon enough. If you do not have any of these products readily available to you, there are hoards of organic cleaning products now available on the market and available at grocer stores, home improvement and hardware stores.
Cleaning with Vinegar
While vinegar may not have the most pleasant odor, it can do wonders from cleaning windows to coffee stained coffee makers. Use white vinegar as a cleaning agent mixed with equal parts of water to remove solid stains, waxy build-up on mirrors and countertops, as well as mildew. It leaves windows and mirrors shining and streak free and coffee maker glass carafes free from old coffee stains. Vinegar also works well on cleaning old paintbrushes.
The Best Uses for Baking Soda
One of the easiest and cheapest ways to clean your home from top to bottom is with a box of baking soda. Once mixed with equal measurements of water, it can be the miracle cleaner you have been looking for. Baking soda helps to clean and deodorize, as well as serve as a scouring agent, polisher, stain removal and fabric softener. Use it also to clean your plastic, vinyl, carpet, silver, stainless steel, drains and refresh your fridge. As a paste, it can be used in kitchens and bathrooms to make them shine. Using baking soda in stinky areas of the house helps neutralize foul odors.
Easy Laundry Deodorizer
Add ½ cup of baking soda to your wash to deodorize clothes. You can buy detergents that contain the ingredient, or simply add it straight from the box. Because it’s so cost-effective, buy several boxes and place in the refrigerator or closets. After three months, pour old baking soda slowly down the drain or garbage disposal to freshen and reduce odors.
The Many Uses of Fabric Softener Sheets
Eliminate ugly odors in your garbage cans or laundry baskets by placing a dryer sheet at the bottom of the wastebasket or hamper. Another use for fabric sheets is to remove unsightly dust from reappearing on your Venetian blinds by wiping the slats with dryer sheets. Keep rodents away from stored pantry items by placing a dryer sheet in the pantry area. Dryer sheets also serve as economical deodorizers for shoes or sneakers; place a sheet in them overnight. Dryer sheets can also help collect work room shavings from woodworking, sandpapering or drilling similar to what a tack cloth can do from a hardware store.
Lemon and Oranges
Lemons and oranges are two strong citrus fruits than can be used to freshen up drains, garbage disposal as well as used to clean tile work. Simple squeeze the juice of a lemon or orange onto the countertop and spray with water for a quick stain removal procedure.
 forum activity
