Login Error
Close
Paint a Pool Slide in 5 Steps
by DoItYourself Staff
what you'll need
  • Pressure washer
  • Scrub brush
  • Ramuc Clean and Prep Solution
  • Gloves
  • Goggles
  • Marine fiberglass epoxy putty
  • Putty knife
  • EP High Build Epoxy Paint
  • Rollers
  • Brushes
  • Drop cloths
If you want to paint a pool slide you can add a fresh coat and make it shine like new in 5 straightforward steps.
Step 1: Preparation
Surface preparation is critical when painting a pool slide or swimming pool, and if done poorly you’ll almost certainly have problems. For best results, make sure to paint when the weather conditions are right - meaning low humidity, low chance of rain and temperatures between 50 to 90 degrees Fahrenheit. Painting in cooler temperatures will hamper proper drying, aesthetic appearance and can lead to peeling. If more than a quarter of the existing paint surface is already peeling then you might need to think about removing the entire surface by sandblasting before moving onto the next step.
Step 2: Clean the Pool Slide
First remove any dirt and loose paint with a pressure washer. This should be no less than 2000 psi. Let the surface dry thoroughly. Most pool slides are made from fiberglass, so you’ll then need to scrub the surface with TSP (Trisodium phosphate). This acid wash will remove all mildew, stains, grease and dirt. However, be sure to avoid contact with skin and eyes and wear chemical resistant gloves and goggles at all times when handling. Use in a well-ventilated area, preferably outdoors. If you prefer not to work with TSP, Ramuc offers a Clean and Prep Solution that works well and eliminates the need for the difficulties that come with acid washing.
Step 3: Repair Cracks
Now that the surface is prepared you can touch up any cracks that might be a problem. Fill in the gaps using a marine-type fiberglass epoxy putty and a putty knife.
Step 4: Choosing Paint
Choose an epoxy paint that is suitable for fiberglass. Both Ramuc Type EP Epoxy or EP High Build Epoxy are good for painting pool slides. If applied correctly, High Build Epoxies will last 8 years or longer. There's a vast selection of colors to choose from, and it forms an abrasion-resistant surface that’s easy to clean.
Step 5: Painting the Pool Slide
You will again need proper ventilation when working with epoxy paint. Avoid direct contact and make sure to use quality tools. Follow the manufacturer's directions carefully regarding quantity and application of your pool slide paint. Too thin a coat will not give your slide the weather protection or slickness required for proper use and enjoyment. A coat that's too thick will result in bubbles, blisters and having to redo the entire project. The good news is you can use a roller for both coats, but be sure to wait at least 15 to 75 hours before adding the second coat.
Now all that’s left to do is enjoy the ride. Don’t forget to allow the paint to cure for at least 5 days before you take your new pool slide for its first test run.
 forum activity
