Login Error
Close
Paint Ceiling Tiles in 4 Steps
by DoItYourself Staff
You can paint ceiling tiles if they become too stained to clean, or if you want to change the color. Here are the 4 steps to paint ceiling tiles.
Step 1 – Start Fresh
Start by washing the ceiling with a light bleach and water mix. Spray lightly and then wipe. This will remove any film on the tile and allow the paint to adhere better.
Step 2 – Gather Your Supplies
You are going to need the following:
  • latex primer - how much will depend on the size of your bathroom
  • paint – how much will depend on the size of your bathroom
  • 4 Foam Rollers
  • 2 Paint Trays
  • 1 Cutting Paint Brush
  • rags
  • newspaper
Step 3 – Remove the Tiles
To paint ceiling tiles remove from the ceiling and lay the tiles on a tarp on a flat surface.
Step 4 – Paint Ceiling Tiles
When you paint ceiling tiles you can expect them to soak up a lot of paint. The primer is designed to reduce the amount of absorption but be prepared to apply several coats of primer.
Use your roller to apply the paint. Choose an eggshell or flat finish to reduce reflection. You need to keep the tiles flat until they are completely dry or they will warp.
 forum activity
