Login Error
Close
Paint Stain Removal
by DoItYourself Staff
Paint stain removal could be a noble act of bringing back the former beauty of your home. If the process of painting as in a home improvement endeavor is done by an inexperienced person there could be a lot of stain on the floor and walls by drops that come from the poorly held painting equipment.  Depending on the extent of the mess the process of paint stain removal can be easy or extensive.
Paint Stain Removal Checklist
To achieve the best and intended results in paint stain removal you should check the following before beginning:
• The state of the paint stain; Know whether the paint is dry or wet for they two have different paint stain removal processes.
• Check whether the stain is from water or oil based paint for their paint removal procedures are different. The oil based paint stain removal needs more precautions than the water based and can worsen the stain if care is not taken.
• Research on any toxin or reaction that can be experienced as you use the paint stain removal substances.
• Assess the available equipment and materials so that the function can be undertaken smoothly.
 forum activity
