Login Error
Close
Painting a Metal Screen Door Step-by-Step
by DoItYourself Staff
what you'll need
  • Metal spray paint or paint from a can (intended for metals only);
  • Metal primer, and;
  • Brush (if using paint from a can)
Painting your metal screen door is a great do-it-yourself project and does not require many materials to complete. Gather the materials below and follow the easy step by step instructions to get your project off the ground.
Step 1 – Clean the Door
You want to make sure all dirt is removed from the door. Follow these steps to clean it:
  • Use an ammonia and water solution to clean all loose dirt from the door. You can use a scrub sponge to help clean it.
  • If the door is constructed of steel, you will want to remove any rust that is present using a wire brush. On aluminum, an oxidation process occurs but it doesn’t rust. You don’t have to do anything special to that.
  • Tape of any areas that you do not want to get paint on using blue painter’s tape.
Step 2 – Prime the Door
You will want to use a good metal primer before actually painting the metal screen door. This adds an additional step, but in the end it helps to protect the door and it will assist on making sure the paint adheres to the surface being painted.
Step 3 – Paint the Door
If you are brush painting, you will want to be sure to put the paint on in nice even coats. Do not paint “back and forth”. Paint in one direction only. This will help to prevent brush lines and streaks.
If you are using spray paint, many thin coats of paint are much better than one thick coat. This will also prevent runs and the layers will dry relatively quickly. The end result will be a much smoother finish for the door and it will look brand new.
 forum activity
