Painting Ceiling Tiles the Right Way
Painting ceiling tiles can have a big impact on restoring the original shine to a room when done correctly. Whether they have become dirty, or you wish to change the ceiling color, painting them can be done in just a few steps. Ceiling tiles can be rather fragile, so following these steps will ensure that you keep your tiles intact during the process.
Step 1 – Select Your Paint and Gather Supplies
You will need:
- Latex primer (amount depends on size of ceiling)
- Paint (amount depends on size of ceiling)
- Foam roller
- Paint tray
- Rags
- Newspaper
- Bleach
- Spray bottle
- Water
Step 2 – Remove the Tiles
Lay the tiles on a flat covered surface.
Step 3 – Clean the Tiles
Create a weak bleach solution with the bleach and water in a spray bottle, and clean the tiles gently using a rag. By removing the dirt and grime from the tiles, the paint will stick better and look better in the long run.
Step 4- Apply Primer
First apply the primer to the tiles to reduce the paint absorption. You may need to apply several coats. Allow time for the primer to dry thoroughly.
Step 5 – Paint the Tiles
Once the primer is dry, apply the paint. Be sure to let the tiles dry completely before putting them back in place, as they will warp if wet.
