Login Error
Close
Painting a Geometric Wall Mural in the Powder Room
by Alyssa Davis
By their very nature, powder rooms are not very big.  They tend to be tucked into the space under the stairs, in a short hallway or nestled in an area off of the main rooms.  While they provide a much needed and practical function, their small space can be challenging to decorate.  If you add too many decorations, the space will quickly become overpowered.  By the same token, if you do not add enough decorations, the powder room will look barren and bland.  Painting a geometric wall mural in the powder room is the perfect way to combat both decorating faux pas.  The ideas below can help you get started.
So Square
One of the challenges of any powder room is the tendency to feel like you are in a small, cramped space.  Give the illusion of a longer and wider room, by painting squares on the wall.  Use multi-colored squares, or choose one color, and paint them in a straight line along the wall opposite the door.  This line of squares will visually break up the wall and make it appear longer than it actually is.  You can also paint squares along the wall behind the toilet to lengthen that space, as well.  To paint the perfect squares, use a t-square; this will ensure that your lines are straight and that the angles are at 90-degrees.
Bubbly Circles
For a more cheerful look, use circles to enhance the look of your powder room.  Bright bold colors will make the space feel much different than more neutral, light colors, so choose the color combination that will work best for your space.  Remember, that you do not want it to be a shock for people to enter the room, and that the powder room’s decor and colors should tie in with the colors of the hallway or room that it is located next to.  Use a compass to help you draw smaller circle and create your own with a pushpin, length of string and a pencil to make a larger circle.
Tumbling Triangles
If adding movement to your powder room through the use of geometric shapes is important to you, create a tall, tumbling tower of triangles.  The triangles can be done in the same colors, or use a graduated palette of colors.  For example, start with a deep, dark blue for the bottom triangle and gradually lighten the blue as you move up the triangles.  This stacked tower of triangle shapes will make for a focal point that lifts the eye and gives added height to the powder room walls.
Geometric shapes are often overlooked when the discussion of murals comes up. However, they offer great variety and can enhance the look of any room, but especially a small powder room.  Use a single shape to create the look you want, or combine a variety of shapes to give your room a unique look.  By using geometric shapes, your room is sure to have a modern look that cannot be beat.
Home design expert, Alyssa Davis of Metal-Wall-Art.com, is particularly skilled in designing with decorative metal coat racks and metallic wall sculptures.
 forum activity
