Painting Over Wallpaper Borders
what you'll need
• Hairdryer
• Spray mister
• Plastic wallpaper scraper
• Sandpaper
• Primer
• Good quality paint
• Paintbrushes
• Roller
• Joint compound or drywall mud
• Fine grit sanding block
Difficulty:Novice
Time:A weekend’s worth or work and drying time Wallpaper borders can be quickly become dated and old. You can refresh a room by removing the borders or painting over them.
Step 1 – Assess the Border
Kids’ wallpaper borders are often attached with weak adhesive, because the interest of a child changes. For example, a cute bear border may be fine for a 4-year old, but not for a 14-year old. Accordingly, you may be able to peel these off without any need to paint over them. Kitchen wallpaper borders, on the other hand, are usually well attached, as the steam of the kitchen makes wall coverings work harder to stay looking good. Bathroom wallpaper present the same challenge. If you are not able to peel of the paper and the underlying glue, you need to do a little prep work before you paint it. Run your hand over the edge of the border and the wall, you will feel a small ridge. If you do not even out the surface where the border meets the wall you will see this ridge after you paint.
Step 2 – Try to Remove the Wallpaper
You will get the best finish if you remove the wallpaper border before you start to paint. The easiest method is to heat up the border using a hair dryer. The heat can loosen the adhesive and make the border easier to peel away. If this doesn’t work, moisten the surface lightly with a spray mister and scrape with a plastic wallpaper scraper to avoid damaging the walls. Use a plastic scraper instead of a metal one to avoid structural wall damage. If this does not work, painting over the border is your next option.
Step 3 – Prepare the Surface
As with any painting job, you will get the best finish if you prepare the surface of the wall thoroughly. Gently remove any loose wallpaper by pulling at it gently with your fingers. Do not leave any torn off bits hanging off. Make sure that the surface of the wall around the border is flat and fill in any holes.
Step 4 – Apply Primer
Most decorating jobs require only one coat of good quality paint. However, when you are painting over wallpaper borders, make sure you apply a coat of primer. Apply it thinly and evenly at first, paying careful attention to problem areas. The best way to apply primer is with a roller for general coverage, and then a brush to target specific problem areas. Leave the primer to dry overnight and inspect the coat carefully in the morning. Then, go through it once again to cover up any imperfections.
TIP:Our painting consultant Pam Estabrooke, of ProTect Painters, suggests, “Tint the primer to the final wall color. This provides greater coverage of the border design and cuts down on bleed through.”
Step 5 - Even Out the wall
Now that you have sealed the paper with primer, even out the border and remove the hard edge or ridge. Load the edge of the plastic putty knife with small amounts of joint compound or drywall mud. Apply a gentle, thin coat of the mud to the lower edge of the border and wall. Continue around the room until all of the edge is covered. Allow it to thoroughly dry and then lightly sand it smooth. Test the area with your hand again and re-mud and sand any areas that still have a ridge or rough spot. It is important to do this after priming, otherwise the water in the drywall mud will activate the paper and glue and can cause the border to bubble and turn loose from the wall.
Step 6 – Apply Paint
Once you are satisfied with your preparation, apply the paint to the wall. Be generous with your paint. Use the best quality paint that you can afford because cheap paint can be thin and does not provide sufficient coverage. For the best results, leave the wall to dry thoroughly and give it a final coat.
Pam Estabrooke, district manager of ProTect Painters, contributed to this article.
