Login Error
Close
Painting Wood Fireplace Mantels: A Guide
by DoItYourself Staff
what you'll need
  • Dry cloth
  • Claw hammer
  • Screwdriver
  • Masking tape
  • Water
  • Rubbing alcohol
  • Paintbrushes
  • Medium-grit sandpaper
  • Primer
  • Paint scraper
  • Wood paint
  • Painters tool
Homeowners with fireplace mantels should periodically spruce-up the mantel, since it is integral to the overall appearance of the fireplace. A fireplace is usually one of the focal points in a house, and its contribution to the interior aesthetics is further emphasized if the accompanying mantel has a lustrous, vibrant exterior. Wooden mantels are fairly common, but they need more regular care and painting than natural stone mantels. Painting wooden fireplace mantels is relatively easy. It's a short project, involving basic skills. The needed supplies are easily available and there is no real risk of causing any harm to the mantel or the fireplace.
Step 1—Getting Started
Prepare yourself with a pair of rubber gloves. Lay sheets of old newspaper over the surrounding surfaces. Remove all showpieces or any other objects placed on the mantel. Inspect the mantel for any old screws or nails. Use a claw hammer to remove the nails or a screwdriver to remove screws. Cover the edges of the wall and fireplace around mantel with masking tape. Use a dry cloth to wipe the mantel clean.
Step 2—Stripping Wooden Fireplace Mantel
If the wooden fireplace mantel has been painted before, you need chemical stripping. The uppermost layers of paint can be scraped with a painter's tool. Buy a branded, chemical paint stripper. Apply the stripper solution according to packaged instruction with a paintbrush. Allow the stripper to work upon the mantel surface for about 15 minutes, or as per the packaged instructions. Sometimes there are multiple layers of paint. This is most apparent when the chemical stripper doesn’t seem to strip-off the paint properly and traces of underlying paints become visible. Here, you need to re-scrape the stripped surface with a carbide-tipped scraper and repeat the chemical stripping with a thinner coating (minimal chemical stripping).
Step 3—Sanding Plain Wooden Fireplace Mantel
If the mantel has not been painted before, stripping is not needed. You can prepare it for painting with some basic sanding. Sand the wooden mantel with 100-grit sandpaper. This creates a cleaner, paint-friendly surface that bonds better with the primer and the paint. You should sand in the direction of the grain of the wood and not against it or in circles.
Step 4—Cleaning Sanded/Stripped Fireplace Mantel
Before applying paint to the mantel, remove traces of sanded wood debris or stripper solution. Traces of the chemical stripper are best cleaned with a cloth dipped in rubbing alcohol. For sanded mantel surfaces, wipe the mantel with a damp cloth. This is the easiest way of removing the dust/debris created from sanding. Allow the mantel to dry for at least an hour.
Step 5—Applying Primer
Using a paintbrush, apply a single coat of primer. Start from the bottom of the mantel and move upwards. Apply the primer in thin layers, moving in one direction, with gentle strokes. Let the primer dry according to packaged recommendations.
Step 6—Coating Mantel with Paint
Semi-gloss acrylic paints are a good choice for painting wooden mantels. Using a similar technique, apply a single coat of paint, moving in the direction of the wood grain, with a paintbrush. Allow the first coat to dry. This can take more than 12 hours. Apply consecutive coats depending upon your shading preferences and the packaged recommendations.
 forum activity
