Login Error
Close
Patch a Popcorn Ceiling: 6 Mistakes to Avoid
by DoItYourself Staff
If you have a popcorn ceiling, you’ll know it offers several advantages. Perhaps the most important is that it makes a room more soundproof. When it needs patching, however, it can be easy to make mistakes that can ruin the look and stability of the ceiling. You need to know what not to do as much as the things you should when you’re patching your popcorn ceiling.
Mistake #1--Missing the Real Problem
It’s fine to patch your popcorn ceiling, but if you don’t find the problem that caused you to need to patch it in the first place, you’ll only have to do it all over all again very soon.
There could be any number of reasons, but you need to find and fix the root cause before you go ahead and patch the ceiling. If it’s due to dampness, find the reason it has become damp and take care of it. If it’s structural, fix it before it becomes even worse.
Mistake #2--Failing to Match Texture
In order to have a repair that doesn’t look like a repair, you need to be able to match the texture of your popcorn ceiling. There are three types of aggregate you can buy for a popcorn ceiling: fin-grade, medium-grade or coarse-grade. These grades give you a start, but from there, it’s a matter of trial and error in terms of application.
Experiment on an old piece of plywood, adding more aggregate until you’ve succeeded in matching the texture before you apply it to the ceiling.
Mistake #3--Using the Wrong Amount Of Texture
You not only have to match the texture but also the amount of product you put on a popcorn ceiling when you patch it. This, once again, comes down to trial and error. It’s much better to start off with too little and then add a second and third coat as you need them. Putting more on is much easier than trying to take some off. Wait until one coat has dried before you apply the next.
Mistake #4--Applying the Texture to Non-target Areas
When you have a target area on your popcorn ceiling that you need to patch, you should be very careful about covering the other areas. If you fail to do this, you’ll end up with far too much texture on the surrounding areas, which will make the patched area of the popcorn ceiling stand out.
Mistake #5--Spraying On
When you’re patching a popcorn ceiling, don’t spray on the texture. You will have far less control if you do this, and the patch may look like little more than a shoddy repair. It’s much better to use a roller. It will take longer, but if you do it well and take your time, the patch will be seamless.
Mistake #6--Neglecting to Sand
Don’t just cut out an area to patch. You also need to sand the surrounding area so you’ll be able to blend in the texture properly. Also, remove all the old texture from the area where you want to patch. This will make any new work on the popcorn ceiling look a lot better.
 forum activity
