Patching a Textured Ceiling: 5 Tips
Repairing a textured ceiling that has suffered a little damage is often easier than covering the entire surface. By following a few steps, you can avoid resurfacing the ceiling and undertake a repair so that you can retain the existing texture.
1 - Preparation
To ensure that you do not cause damage to the surrounding area, whether it be the floor or the existing ceiling, you should start by putting some protection in place. Lay a drop cloth immediately below the repair site, arranging it so that it does not interfere with the feet of the ladder. Prepare the section of the textured ceiling that is to be repaired by cleaning away any loose particles and debris with a soft bristle brush to ensure that the repair takes.
2 - Tools
Make sure that you have all the necessary tools and equipment to hand before you begin to repair the textured ceiling. Depending on the material being used and the size of the repair, you may only require a few basic tools. Many fillers will not require a significant amount of effort or a great number of tools to apply.
3 - Material
There are a range of materials that can be used to undertake a patch repair to a textured ceiling and it is prudent to use the same substance as that of the existing surface. However, if it is not clear, use a substance that is close in color and that can be amended as well as being appropriate for repair. In addition, the material you use for a ceiling patch will depend on the size of the area to be repaired. Spackle will be suitable to fix small defects, while drywall compound will be more appropriate for larger problems.
4 - Technique
The technique you use to repair a textured ceiling effectively will depend on the design that is required to complete it. All repairs will begin with you gradually applying the chosen filler to the defect until it is completely filled. A flat surface can be created by drawing a scraper over the surface to remove the excess and leave a smooth result. It should then be left to dry to complete the repair before paint is applied if necessary.
Swirled designs will require a little more effort to replicate. After filling the defect, use the flat tip of a putty knife to manipulate the wet repair compound until it looks like the existing ceiling. This technique may work better if the material is left to dry slightly until it becomes tacky, allowing you to gently create peaks or circular patterns. For more intricate patterns, cut a piece of cardboard to the appropriate size and use this to create the design.
5 - Color
Though the color of a repair job can be adjusted by applying paint, this will become unnecessary by choosing a material that is already the same color as the ceiling. Reduce the need for additional work by choosing a substance that is capable of small color changes. For example, the color of drywall compound can be slightly changed by increasing or lessening the amount of water added.
