Login Error
Close
Patio Furniture Rust Removal
by DoItYourself Staff
Even if you don’t have metal patio furniture, you’re likely to find some rust on exposed metal parts of plastic patio furniture. Not only is it unsightly, but it can leave stains on clothing, and constant exposure to rust can be problematic to small children and pets. Also, rust from your patio furniture can seep onto concrete, creating stains. Here’s a brief guide to removing both light and heavy rust.
Rust Removal Items
  • Rags
  • Scouring brush or steel wool (light rust removal)
  • Kerosene or mineral spirits (for clean up and removal of rust stains)
  • Lemon juice and vinegar (medium rust removal)
  • Scrapper (medium and heavy rust removal)
  • Steel wire brush (medium and heavy rust removal)
  • Naval jelly or rust remover product (heavy rust removal)
  • Sandpaper (metal)
  • Rust-proof primer (metal)
  • Rust resistant spray paint (metal)
Removing Light Rust
Use some type of scouring brush or pad, like steel wool to remove light rust. In some cases, what appears to be rust are merely rust stains, which can be caused by accumulation of water on certain parts of your furniture. In this case, kerosene can help remove some of these stains (just make sure you’re in a well ventilated area and away from open flames).
At this juncture, you may still have some rust that will be visible. However, depending on the style and type of your patio furniture, some people like a ‘rustic’ look. If you’d like to stop here, you should apply a clear coat paint or car wax over the rusted areas. This will maintain the rust, yet inhibit new rust from forming. If you choose to remove the remaining rust, move on to the next stage.
Removing Medium Rust
Use a wire brush (with medium stiff bristles) for removing medium rust. Make sure to look for bubbled up paint, indicating there is rust underneath.  If so, scrap off well and sand down with sandpaper or steel wool.  If you plan on painting your furniture after removing the rust, consider using a commercial rust remover product; they are very effective.  Note that there are some “green” options as well, from commercial products to ‘home’ remedies such as lemon juice and vinegar. Due to their acidity, these home remedies adequately remove some rust stains (especially if they’re not too old) but don’t count on these methods for heavy duty jobs.
If you don't want to repaint the patio furniture, you can try an organic rust remover which doesn't have acid or harsh chemicals. They’re convenient and eco-friendly.
Removing Heavy Rust
For heavy rust removal use a scrapper to remove paint flakes and bubbles, and a wire brush (coarse or stiff bristles) to remove the remaining rust. Afterward you can apply a commercial rust remover product. You can use naval jelly or a rust “converter”. A converter removes the rust while leaving bare metal (especially useful if you plan on restoring wrought iron to its original condition). Another type of converter will blacken the offending rust, turning it into a sandable primer type of surface. There are some green products on the market that do a fine job for the more dastardly rust problems.
Finishing with Paint
If you’ve chosen to go beyond a simple clear coat application (once the rust has been removed) you can choose to paint your patio furniture with a rust resistant metal spray paint. Spray paints in aerosol cans are preferable if you want to eliminate the use of a paint brush and avoid drip marks.  However, if you want to customize your color or want to avoid aerosol fumes, you can use a brush. If need be, first prime with a rust-proof primer before painting. If you used a rust converter, you can skip the priming process.
Plan on having some mineral spirits on hand for cleaning since rust resistant paints are oil based. If you decide on repainting, pause to take the time to think about color. Rust can be camouflaged better with certain colors, like rust or dark tan colors, rather than white or black. You might also want to experiment with bolder colors (reds, greens and blues), assuming this fits with your outdoor décor.
Remember, you can minimize your trial and error by asking neighbors how they maintain their patio furniture or by getting some recommendations from your local hardware store. Lastly, calculate the cost, time and effort required to restore your furniture. You might find that starting your rust prevention initiative on a new set of patio furniture might be warranted.
 forum activity
