Login Error
Close
Peel and Stick Garage Floor Tile
by DoItYourself Staff
You have probably heard about peel and stick garage floor tile. This kind of flooring option has become popular mostly because of the convenience it brings.
Installation
Peel and stick garage floor tile comes as what you assume them to be. Installing them involves two steps: peeling off its back part and sticking it to your floor. This garage floor tile option has been a sought-after choice for those who barely have the time to make improvements at home. Since this kind of garage floor tile does not need the use of epoxy or other sticking substances, you have the benefit of doing the project only when you are available.
Preparation
Like all other garage tile options, installing peel and stick garage tiles also requires preparation. You should first thoroughly clean the area where you plan to stick them. Dusts and debris can stick to the garage tile and and the tile will not then stick well to the floor.
Source
Peel and stick garage floor tile may be a little hard to find. Because of its limited supply, you might have to consider looking for them in big and trusted do-it-yourself shops, construction supplies stores or home improvement depots. They also come in a variety of patterns and designs that you can choose from.
 forum activity
