Pellet Stove Vaccum (Ash Vacuum) Cleaners
Using a pellet stove vacuum cleaner or an "ash vacuum" can make cleaning the ashes in your fireplace much faster and easier without making a mess. Working similarly to a conventional vacuum cleaner, the pellet stove vacuum will clean up ashes and other debris within a matter of seconds.
Both Hot and Cold Ashes
Many products will allow you to vacuum up ash even if it is still hot from the fire. The manufacturers of these products have made all the parts, including the hose, resistant to fire, enabling you to clean up as soon as your fire has died out.
Many Sizes and Styles Available
Depending on which company you go through, you will have access to many different sizes and capacities of vacuum cleaners, so you will be able to pick the one that will best suit your needs.
Most come with a hard, removable container that will hold up to 3 to 5 pounds of waste. When it is full, you simply need to throw out the old ashes in your trash can or dumpster and reassemble your machine.Some come with extra features and gadgets as well that allow you to do additional clean-up in your fireplace.
Using a pellet stove vacuum can save you a lot of time and effort and it is one of the easiest ways to keep your fireplace clean.
