Login Error
Close
Perfecting Your Garden's Look with Stone Garden Edging
by DoItYourself Staff
Stone garden edging can offer a very pleasant touch to any garden, and what’s more, it is not particularly difficult or expensive to install. It also helps to protect your garden. It can stop grass from growing into flower beds and help prevent the spread of weeds. By providing an attractive and practical border, is conveniently keeps everything in place. There are various different options available to suit any kind of garden.
The Reasons for Stone Garden Edging
Although it gives your garden attractive look, stone garden edging acts as an important physical barrier. It also requires minimal maintenance due to its high durability. The edging should extend slightly above the surface of the soil as this prevents grass or weeds from the lawn encroaching onto the flower bed. Normally made from stone, garden edging also adds an elegance and charm to your garden. It can also highlight the flowerbeds and make them more distinct. They can also be placed around tree trunks as well as at the bottom of fencing.
Types of Stone Garden Edging
There are many different methods of garden edging. Stone garden edging is one of the most popular and most attractive options. It is also practical and effective if it is applied correctly. Stone edging is the most traditional and considered by many to be the nicest. It is not particularly expensive either. Installing it is easy, and requirements are minimal. There are many different kinds of stone edging as well, including river rocks, slate, field stones or brick.
Things to Consider with Garden Edging
Garden edging does not have to be complicated, but it is time consuming. It needs to be leveled correctly and installed carefully. If you want to get professional results, you may want to consider the services of a professional gardener or landscaper. This is especially the case in more complex projects, but if you are simply applying stone edging around a flower bed, you can easily do it yourself.
The only material you need is the stone itself, which, if you don’t have lying around your property already, you should be able to acquire easily from any gardening center. Make sure you purchase enough material to do the entire job. It is always a good idea to have a little bit extra.
To get the best results, it is a good idea to place the edging quite deep. This will further help to prevent the encroachment of weeds on to your flowerbeds. Having a solid barrier will not only look better but it will help protect your garden as well. For an extra barrier, you can also install sheets of fabric up on the inside of the edging.
To hold the edging in place, make sure that there is no loose dirt between the bricks or stones. They should not easily tilt or fall out of place. They need to be packed in tightly and soil should be packed firmly against the edge.
 forum activity
