Login Error
Close
Permanent Wood Foundations Explained
by DoItYourself Staff
Foundation-repair issues can be minimized, if permanent wood foundations are established. Usually, establishing permanent wooden foundations includes the use of treated lumber. Here, panels of wood are pressure-infused with special chemicals commonly referred to as preservatives. This chemical treatment is useful for protecting the wood against foundation-maintenance issues like mold infestations and decay due to moisture seepage. The panels are strengthened with wood-fasteners made of stainless steel that are immune to chemical and moisture-induced corrosion.
Understanding Wood Foundation Attributes
Wood is a much better choice than concrete for establishing durable foundations. Wood foundations offer better resistance when subjected to neglect and tend to offer better thermal insulation. This makes them ideal for homeowners who want to create a foundation system that needs minimal maintenance and contributes to energy conservation within their home. Wood foundations are more elastic, making them less susceptible to cracking under weather-induced problems like expansion or contraction. The elimination of concrete foundation-based components makes wooden foundations a more affordable option. Permanent wooden foundations offer many other advantages, including:
Installation & Handling Ease
Wood foundation panels are much lighter than concrete blocks. Thus, they can be easily placed over gravel beds fortified with crushed stone bits and coarse sand. This eliminates the need to prepare a cemented footing that is common in concrete-foundation installation. This also reduces the installation time. Basements prepared with wooden foundations are easier to maneuver for internal insulation. Wooden foundations are more adaptable to the addition of insulation materials like cellulose layering. Addition of batts is often recommended for insulating the foundation. Application of batts is very expensive among concrete foundations as industrial adhesives and specific studs are needed to bind the batts with the concrete. However, batts are easy-to-install within wooden foundations. Working with wooden surfaces makes repairing of basement-based, plumbing and wiring, undemanding. Wood joists are easier-to-handle during HVAC installation.
Repairing & Finishing Ease
Concrete-foundation repairs need casting/curing that is often weather dependent. Wooden foundation installation and repairs can be executed in any weather since weather-related problems associated with concrete foundations are eliminated. Precut wood panels are installed with framing crews that can easily replaced if a panel appears slightly destabilized. This can be done with basic, household tools, without the need to employ professional help. Wooden foundations can be easily finished. Usually, the finishing is undertaken by the foundation installation/carving contractors. Here, finishing doesn't need chase construction, masonry adhesives and complex cutting gear that is used for concrete finishing. In fact, wood-foundation finishing can be done by homeowners themselves. Many easy-to-follow, foundation-finishing kits are available at hardware supply stores.
Unquestioned Warranty & Reliability
Wooden foundations have created a niche for themselves in the residential foundation marketplace. As a result, they are often retailed with extensive warranties. Most analysts believe that contemporary wood foundations offer long-term durability, usually lasting for many decades. Further, the durability of permanent wood foundations has been underlined by many official certifications of global repute, like the IRC (International Residential Code). Wooden foundations have constantly met the benchmarks set by the AWPA (American Wood-Preservers' Association). Further, permanent wood foundations are usually compatible with the most demanding of building codes and insurance clauses.
 forum activity
