Login Error
Close
Photo Framing Supplies You will Need
by DoItYourself Staff
When it comes to photo framing there are several supplies that you will need.
Frame
The frame is the most obvious supply. You can make your own frame with materials around the house or you can buy pre-made frames at a craft store.
Glazing
Glazing usually consists of glass or plastic. It separates the photo from the open air, protecting it.
Window Mat
The window mat separates the photo from the glazing. When the glazing is pressed against the photo it begins to damage the photo.
Back Mat
When you purchasing matting, be sure to buy acid free matting. Most mats have acid that will eventually damage the photo.
Backing Board
The backing board stabilizes the matting. It is attached to the frame and sandwiches all the other parts together.
Hinges and Adhesives
Hinges connect the backing board to the front frame. Adhesives attach the photo to the mat backing. When you buy adhesives, make sure that they are acid free.
Ruler and Utility Knife
Use the ruler to help you align the photo onto the mat backing. If you are not using a pre-made frame, use the ruler and knife to cut the mat and backing to the proper size.
 forum activity
