Pitched Roof vs Flat Roof Pitched Roof vs Flat Roof
People find it hard to decide whether pitched roof or flat roof is the better choice for home and buildings. Every home and building has its own unique qualities that would require one of the two styles. Below, you will find the list of advantages of both types of roof that will help you come up with a wise decision when it is your time to purchase one for your property.
Advantages of Pitched Roof
The traditional pitched roof is preferred by many homeowners for a wide variety of reasons. For one, many people love the aesthetic look of this type of roofs. They give off a traditional feel to a home. On the more practical side, pitched roofs are more efficient in water evacuation. Flat roofs have the tendency to retain water on the top of the home or building and stagnant water can damage not only the exterior of the structure but also the furniture and carpet inside once it finds a way to go down.
In geographical locations that are much affected by rains, where water evacuation is a top priority, pitched roofs are the ideal option. It is important to note however, that pitched roof requires water to be correctly directed so that there will not be a concentration of water in some areas of the roof. Water should be directed away from the house or building so it will not stagnate onto your home.
Advantages of Flat Roof
Flat roofs, on the other hand, are more suitable for complex buildings or structures with various levels. This is because if you install a pitched roof on this kind of building, it would require a more complicated rafter system. Flat roofs are also more ideal for large spans since building rafters to support large spans are not only complex but also expensive and impractical.
Compared to pitched roofs, flat roofs are more practical because they are easier to install, come at a much lower cost, and have lower maintenance needs, as they are easier to clean and care for. Not only that, they are also of high quality and high performance, making them the cost-effective option. You can do many things with your flat roof. You have the option for decoration finishes or recreation, which are not feasible with a pitched roof.
The Verdict
When choosing between the two, it is essential to consider the following factors: materials to be used, type of building, purpose of roof, aesthetic and architectural qualities, cost, maintenance, weather and geographical location, durability, and performance. All these elements will help you make an informed choice, one that would be suitable for the type of building and the kind of weather that you have in your place.
