cancel
Job type :
Zip Code :
community forums
comments
Plan Ahead for Your Guest House Remodel
Performing a guest house remodel job is a large project, but it can be completed smoothly and in an organized fashion with a bit of planning beforehand. Please read the information below which will help you to efficiently plan all of the necessary aspects of your remodel.
Plan Your Remodel
Planning is essential when remodeling your guest house. The size of the job will depend on your specific goals and how many steps it will take to complete them. With that in mind, below are a couple of suggestions you should follow before you begin your remodeling project:
   1. Plan out what you want to achieve with the remodeling job. Are you looking to only change the colors and add some new trim or do you want to totally change the layout of the guest house? By knowing what exactly you want to update or change, you can plan accordingly which ensures that the job will be done efficiently and within the desired time frame.
   2. Determine which materials you will need to thoroughly complete the job.
   3. Make a realistic estimate on how long it will take to do the job and set a date as to when you would like it finished.
Stick To Your Budget
In addition to creating a plan for your remodel, you should also prepare a budget. Having a budget keeps you financially on track and helps prevent unnecessary purchases for the project. In general, add an extra 15 to 20 percent in funds to cover miscellaneous or unexpected costs.
member comments
Did-it-myself Projects
updated by LessWire
did this on 4/28/2009
3 Bedroom 1 Bath Addition
updated by SKHK1
did this on 4/12/2008
Two Room Addition
Your Winter Home Checklist
sponsored articles of the day
