cancel
Job type :
Zip Code :
community forums
comments
Planning For Greenhouse Gardening
Greenhouse gardening can be an exciting venture. To ensure that is goes smoothly, make sure you have made the right plans and have everything you need to begin your greenhouse gardening.
What You Need For Greenhouse Gardening
There are some items that you will need to start your greenhouse gardening, you should go over the below checklist to ensure you are ready to start building.
The framework can be aluminum or wood, depending on your taste and style. Painted aluminum will last the longest and look great.  The glazing can be tempered safety glass, opal root, twinwall, or triplewall.
For the foundation you will need pressure treated timbers, concrete block base wall, and a concrete slab or tile. The concrete slab will work as the floor, if you do not pour a slab, then a walkway should be made down the middle for easy greenhouse gardening.
There are accessories that can be used in greenhouse gardening that offer beauty and function to the greenhouse.
• Shading
• Benches
• Heating
• Air Circulation
• Misting System
The above accessories make greenhouse gardening easier and more enjoyable.
More Reading
member comments
Did-it-myself Projects
updated by Keith719
did this on 10/05/2009
Stone Entrance Way
updated by PMeans123
did this on 1/10/2009
Drainage Around Barn
updated by Grandma Fixit
did this on 9/21/2008
The Wall
Your Winter Home Checklist
sponsored articles of the day
