Planning a French Drain
On to Part 2 - Building a French Drain
People have been faced with the problem of getting rid of excess water on their property for hundreds of years and one method that has stood the test of time is a French drain. Essentially a small, covered stone filled ditch, French drains take advantage of the power of gravity to create a route for the excess moisture to be channeled from where it isn’t wanted to an area where it won’t be a problem. Besides helping turn wet, soggy garden areas into productive ones French drains can also be used to channel run off water away from a home’s foundation and help prevent basement flooding.
What’s French about a French drain?
In reality there’s nothing really French about them. Although some people say the name comes from the fact the sewers of Paris in the early 1800’s were simple open ditches, most attribute name to a Massachusetts farmer named Henry French. Reportedly, he came up with the idea of using small stone filled ditches to drain water off his farmland back in the late 1800’s.
How do French drains actually work?
The idea is simplicity itself. Dig a trench running from the wet area towards a dry or unused area, line it with stone to prevent soil erosion, install PVC piping to channel the water and cover it up. Depending on how much water needs to be moved the drain itself can be as narrow as 6” or as wide as 2’.
The only tricky part is for the water to flow, the drain needs to have downward slope with a 1% grade. (In other words the drain must go down 1’ for every 100’ in length).
Planning a French drain
While the concept of a French drain is simple, installing one requires some up front planning and preparation before beginning.
Since a French drain needs to start at a high point in your yard and run to a low point you need to determine the best route it. Preferably, look for an area running along the edge of your property where digging would be relatively easy. You need to consider if your planned route will impact how you actually use your yard (does it run through a kid’s play area or near a family fire pit?) or if it will impact any planned home improvements.
After you have determined your drain’s routing remember you will need to ensure your finished drain has the proper 1% down slope. You can either do this by having a survey done or do it yourself using two wooden stakes, a line level and a piece of twine. Here’s how -
- First, drive one stake in at the top end of your drain and fasten the string to it.
- Next go to the far end and loosely tie the string there.
- Attach your string level and level the string, adjust the loosely tied end and fasten it.
- Now, since your drain needs to fall 1 foot for every 100 feet of it’s length, you can easily calculate how much it needs to go down along its length. (For example a 50 foot long drain need to go down 6” in total over it length). Simply move the string on the lower stake down the necessary amount and it will be a guide for the proper grade.
Some other considerations
Building a French drain isn’t complicated, but it does require a lot of digging and physical effort, You might want to consider renting a small trencher or hiring a backhoe to do the digging for you.
Before you actually start to dig, be sure to call DigSafe (888-Dig-Safe) http://www.digsafe.com/ to arrange for your local utilities and services to mark the location of their facilities on your property.
Make sure the end of your French drain won’t end up dumping all your runoff water onto your neighbor’s property. You don’t want to solve your moisture problem by starting a feud with a neighbor.
Murray Anderson is an experienced freelance writer with over 500 articles published on the web as well as in print magazines and newspapers in both the United States and Canada. He writes on a wide range of topics and is a regular contributor to DoItYourself.com. He can be contacted at murand@lycos.com.
