Login Error
Close
Plaster Cornices
by DoItYourself Staff
Decorating the junction between your walls and ceilings with plaster cornices will help hide the small cracks and uneven lines around this area. Aside from hiding the unsightly cracks and uneven lines between your walls and ceilings, decorative plaster cornices can also add character to your room. In fact, the right cornices can help your room look bigger and more spacious than it actually is.
Choosing the right plaster cornices for your room can be a bit of a challenge. To help you pick out the right plaster cornices, here are so tips for you.
Choose the Right Width and Patterns of the Cornices
Before you go shopping for some plaster cornices, you should first take note of the scale and style of your room. For instance, if your room is small, you might want to get plain and narrow plaster cornices to give your ceiling a neat and trim look. On the other hand, if your room is of medium size, you might want to invest in more ornate plaster cornices.
Pay Attention to the Colors of Your Cornices
You need to match the color of your plaster cornices with the dominant colors of your room. If you want to use ornate plaster cornices, make sure that the colors of the cornices do not clash with the colors of your walls and ceiling.
 forum activity
