Login Error
Close
Plastic Cutting Board
by DoItYourself Staff
A plastic cutting board may not be your best investment. They are affordable and easy to clean, but if you do not find a strong one, you will be left with cut marks and gouges all throughout it and it will be tossed quickly.
There are so many different styles of cutting boards to choose from. The plastic cutting board has some advantages over the rest, but being cheap is its major down fall.
Advantages of the Plastic Cutting Board
The main advantage to the plastic cutting board is the fact that it is easy to clean. You can throw it in the dishwasher and be assured no germs are left behind. Other cutting boards, such as wooden ones can have the germs and bacteria from food remain in the grooves where they will eventually form mold and make you and your family sick.
A plastic cutting board may not last as long as the others, but if you are looking for a short term solution, rather than the long term, then a plastic cutting board is for you.
 forum activity
