Login Error
Close
Plastic Garage Cabinets: Pros and Cons
by DoItYourself Staff
When deciding whether or not to go with plastic garage cabinets, there are a few things that you will need to consider, such as cost and durability. While plastic cabinets are fine for most uses, there are some instances where you may want to consider purchasing cabinets made of a different material.
Cost
Overall, plastic garage cabinets are cheaper to buy than wood or metal cabinets. Because of their low cost, they may very well be the best option for you. If you are just looking for a quick fix and are on a limited budget, then plastic is the way you should go. On the other hand, a lot of wear and tear on plastic shelving can cause damage, meaning that they will need to be replaced.
Ease of Use
Plastic garage cabinets are easy to install and easy to clean. The kits come with snap on components meaning that you can put them together yourself. And because they are made of plastic, they will be easy to clean, unlike wood that can stain. Plastic is also water resistant and won't warp or buckle if wet for an extended period of time.
Durability
While plastic is highly durable, if you are planning on storing heavy materials, then you may want to go with a wooden or metal cabinet. Plastic can buckle over time if under a heavy weight and this can lead to eventual cracking of the shelves. And if you have to replace them often, then their initial cheaper cost won't really matter.
 forum activity
