Login Error
Close
Plastic Sheds vs. Metal or Wooden Sheds
by DoItYourself Staff
Metal, wooden and plastic sheds are amongst the most popular for backyard storage. Whether you want to use a shed as a workshop or as a storage unit for your gardening tools, old belongings or equipment, there are several structures that will cater to your need. A shed can vary in size, complexity and cost. Most backyard sheds are simple single room structures with a door. Bigger sheds can look like miniature houses, with shingled roofs, windows and an electric connection. If you are trying to choose between metal, wooden and plastic sheds, consider the pros and cons of each.
Metal Sheds
Metal sheds are usually made from iron, steel or aluminum and offer high-quality and long-lasting strength. The construction of a metal shed typically involves wrapping thin sheets of metal around a central frame. Metal sheds are termite proof and offer superior resistance to bugs, mold, mildew and other fungal growth. These sheds also offer high safety because they are resistant to fire.
On the downside, metal sheds are prone to damage and denting because of the light, thin metal from which they are constructed. Also, a thin metal roof can collapse under the weight of accumulated snow or debris, which is why it is essential to clear the rooftop regularly. A heavy wind can also topple over a lightweight metal shed. Unless properly treated, metal sheds will rust after a few years of use.
Wooden Sheds
The most expensive option of all, a wooden shed offers visual appeal and lasting quality. If you care about the appearance of your shed and want it to blend in well with your backyard, a wooden shed is your best choice. Wooden sheds offer more convenience and flexibility as well. You can add arrangements for storage and also make changes to the structure, if needed. When properly treated and maintained, a wooden shed will last for a lifetime.
In addition to the high cost, wooden sheds have some other drawbacks as well. They are prone to damage from insects, termite, mold and mildew, if not properly stained and varnished. Wooden sheds require considerably more maintenance than their metal or plastic counterparts. It is important to keep plant material away from wooden sheds, to reduce the risk of insect infestation and rot.
Plastic Sheds
Plastic sheds are the most affordable option and also offer great qualities such as durability and security. High quality plastic sheds may cost a bit more, but will last long with no required maintenance. Plastic sheds are immune to the problems you may face with a metal or wooden shed. These structures are resistant to moisture, fire, humidity, insects and rot. You can easily assemble one and also incorporate additions later on. Plastic sheds do not require any protective coating or treatment, unlike wood and metal.
The main drawback of a plastic shed is its lack of visual appeal. Many homeowners may ignore all the above benefits in favor of a wooden shed that enhances the appeal of their backyard.
 forum activity
