Plumbing Code Requirements Explained
The plumbing code is an important building code which can affect the safety of your whole building. Plumbing is one of the most important systems in your house, but it's often overlooked. Plumbing isn't just the pipes which carry water to your home, but also those which carry waste water away. Any problems with plumbing could be devastating to the health of your property which is why it's so important to spend time learning how to correct these problems as quickly as possible.
Plumbing Codes
Many people accept building and electrical regulations, however don't think plumbing deserves the same treatment. The fact is that poor quality plumbing can be just as dangerous as poor electrical work.
There are plumbing codes and it's very important to find out about these before you do any work on your property. The plumbing codes dictate what you can and can't do with the plumbing in your property.
Different for Different Areas
Plumbing codes are actually fairly easy to understand, however you will have a problem when it comes to finding out about the different plumbing codes in your area. The plumbing codes vary between different countries, and even different parts of the country.
Inspection
If you do any simple repairs like fixing a toilet or installing a new water heater then there is no need to hire a professional to inspect your work. However if you do anything more complex like new constructions, or relocating toilets you will either need to hire a professional or alternatively get a professional to sign your work off for you.
Finding the Plumbing Codes
If you want to find your plumbing codes for your local area then you have a few different options available to you. One of the easiest would be to visit your city hall. You should be able to find out about the plumbing codes from the office where you have to apply for your building permits.
If you don't want to go out to get a copy of the building codes then you can look on the Internet. Take a look at your local governments web site so that you can find out about the plumbing regulations in your local area. Almost all cities will use the international codes as a basis for their plumbing codes, but they may alter parts of this code.
Your local library will also normally have a copy of the plumbing codes in your area.
Once you have found out about the plumbing codes be sure to try and stick to them. Failing to stick to these codes could put your property at risk and also leave yourself liable to pay fines.
Uniform Plumbing Code
The uniform plumbing code is the American plumbing standard. Although the plumbing codes will differ depending on different states, it is possible to use the uniform plumbing code to get the basics.
The uniform plumbing code was created in order to protect the public's health from the dangers of poor plumbing.
