Pocket Door Installation Problems and Solutions
There are a variety of problems that can occur with pocket door installation. The good news is that there are ways to prevent these problems and also ways to correct the problems easily. The following tips can help you identify some of the most common problems with pocket door installation and help you to find the best solutions for preventing or fixing these problems.
One of the most common problems with pocket door installation is the doors that come off the track. The traditional rollers that come with pocket doors are not adequate. They often come off the tracks or are not very durable and break. A solution to this problem is to buy rollers that are designed to stay in the track. Rollers that can be released with a simple flip of a lever are also a good idea. This can make door removal easier in the future.
Doors that warp over time are also another problem. The solution to this when doing pocket door installation is to make sure that the header is level and that the side jambs of the door are flush. Leave a small amount of clearance between all of the jambs and doors to allow for warping.
