Polish Marble Countertops: Tips and Mistakes to Avoid
Before attempting to polish your marble countertop, there are a few things that must be considered to assure that you do not diminish its natural beauty. Marble is one of the most chosen materials for kitchens and bathrooms because it gives the room a unique ambiance, and with proper maintenance this uniqueness can last a lifetime. Taking good care of your marble countertops demands that you be informed and persistent in maintenance routines. The results will be worth your hard work. At one time, polishing marble was a tiresome job. Several workers need to scrub the marble surface by hand just to achieve a polish. Modern techniques have developed a lot of ways to polish your marble. Here are some tips in polishing your marble countertop and mistakes to avoid when doing so.
Clean Your Marble Countertop Regularly
Cleaning the marble countertop is one of the important things to do to properly maintain marble. You can use a damp cloth, preferably a chamois or microfiber. Use warm water and a few drops of mild dishwashing agent. Use warm water to rinse the marble countertop making sure that you have completely cleared the countertop of liquid detergent.
Do not use bar or powdered soaps because it will leave a residue on the marble. Also, avoid using bleach and other cleaning products containing alkaline and acid because it will degrade the sealer on the countertop. Vinegar, ammonia, orange or lemon must also be avoided because they contain natural acids. Though a quality sealer is important to protect your marble countertop, it may not always be necessary. In fact, not all marbles require sealing. Some marbles do not absorb sealers leaving them dry on the surface. If this is the case, it is best not to apply them.
Fix Spills Right Away
When you accidentally spill something in your countertop, you should clean it at once so that the material will not penetrate your marble. Materials such as cooking oil, wine, juices, coffee and sauces will stain your countertop. Do not use coarse wipes in cleaning your countertop. You will end up scratching it.
Use Cleaning Products with Neutral pH
Since maintaining a polished marble countertop do not allow either alkaline or acidic substances then having normal pH will not do harm to the marble. It is recommended to also use the polishing products that are specific for marble countertops. These types of products will ultimately provide peace of mind.
Polishing Your Marble Countertop
When you need your marble to look its best, always remember that marble is a delicate material and do not over do it. Apart from cleaning agents with neutral pH, you can use acetone or hydrogen peroxide or clear ammonia mixed with water in polishing your countertops. Acetone is used for light colored marble and hydrogen peroxide is for dark colored marbles. Do not interchange their usage.
Another way on how to polish your marble countertop is with the use of baking soda. Mix 3 tablespoon of baking soda to 1 quart of water and apply it to your countertop, let it stay for 5 hours before rinsing it. Next wipe crushed chalk on your countertop then rinse thoroughly. Wipe thoroughly with a microfiber cloth and you will achieve the polish you desire.
