cancel
Job type :
Zip Code :
community forums
comments
Pond Filter Pad Cleaning and Replacement
Cleaning the pond filter pad is essential for the overall health and well-being of your pond's inhabitants and ecosystem. By following the simple steps below, you can quickly and thoroughly clean and replace your filter pad.
Step 1- Shut Off Power
Make sure all power is turned off to your filter. Since you are working near a body of water, turning all electrical and power sources off while doing this project will prevent any kind of safety hazard from occurring.
Step 2- Take Out Dirty Pad
If the filter looks to be in fair condition,  then try cleaning it with warm instead of replacing it. Keep in mind not to clean the filter underneath a powerful stream of water as this could damage it. If your filter looks torn and damaged, however, then throwing it out is the best option.
Step 3- Replace With New One
Because pond filter pads are inexpensive, you could use a new one each time you want to clean your filter pad. You can keep the older one, if possible, and use it as a spare in case the new one fails.
Step 4- Turn Power On
Once you have changed the filter, turn the power back on to the filter and test it to make sure it is properly functioning.
member comments
Related Articles
Winterizing a Water Garden
Ideas on how to winterize a water garden and care for pond fish before freezing... read more
Seasonal Care for Your Water Garden
How to maintain a water garden throughout the spring, summer, fall and winter seasons... read more
Classic Japanese Tea Gardens
Learn how to transform your backyard into a beautiful, peaceful replica of a classic Japanese... read more
articles we like
Structural Timbers
Structural timbers are wood pieces larger than 4X6, used in framing and structural construction. Structural... read more
Canning Vegetables
Canning vegetables is a simple way of storing freshness and taste. If you are able... read more
Free credit checks expose identity theftFree credit checks expose identity theft
Think you won't be a victim of identity theft? Think again. Thieves steal the identity... read more
sponsored articles of the day
diy centers
