Pool Tile Cleaning: Removing Calcium Deposits
what you'll need
- Muriatic acid
- Sponge
- Rag
- Gloves
- Goggles
- Respiratory mask
The process of pool tile cleaning can be confusing for many homeowners. If you have a build-up of calcium deposits on your pool tile, you may not know where to turn. However, there are ways that you can remove the calcium without damaging the tile. You could pay a professional cleaning company to use a process known as bead blasting. This works well, but if you want to save some money and try the project yourself, follow the easy steps below.
Step 1 - Prepare for the Job
You need to put on protective equipment such as goggles, gloves and a respiratory mask. This will protect you from the harmful fumes that are let off by the muriatic acid.
Step 2 - Mix the Solution
You need to mix up a solution of water and muriatic acid to properly clean the tile. Use a solution of 2 parts water to 1 part muriatic acid.
Step 3 - Scrub the Tile
Use a sponge or a rag to apply the muriatic acid solution to the surface of the tile. You should be able to scrub the calcium deposits off of the tile with this solution.
Step 4 - Wash Off
Once you have scrubbed the tile, you should wash it off with some water.
