Login Error
Close
Power Saver Devices for Electrical Outlets
by DoItYourself Staff
If you want to save on your electricity bill then you will want to consider on buying power saver devices for your home. The purpose of owning a power saver is that it will use less electricity reducing your carbon footprint and saving you money.
Unplug Devices
The best way to save electricity from your outlet is to unplug the devices that are connected to it. Even if the devices are on standby or off they are still using power from the outlets.
Best Surge for You
A device that will help power flow is a surge protector which regulates the amount of electrical current that goes through its device saving you electricity. This device will allow multiple devices to be plugged in and when the surge protector is turned off there will be no leak of electricity escaping unlike a common electrical outlet.
Watt Stopper
This device can be plugged into your outlet which is like a surge protector which offers a feature of motion detection. This feature is a great tool if you only use your device for a short amount of time. If there is no movements in the area of motion sensor then the device will turn it self off. If there is movement then the power will detect you and keep the device on.
 forum activity
