Login Error
Close
Precast Concrete Fence Walls
by DoItYourself Staff
Precast concrete fence walls are a great way to uniquely and eloquently fence your yard or property. These precast concrete fence walls can be designed in any shape, décor, style or color to suit your landscaping needs and to match the exterior of your home. As well, precast concrete fence walls add security and privacy while offering very low maintenance costs.
Flexibility
Precast concrete fence walls can be cast into a limitless number of designs and styles. Nearly any style you desire could be created or found in precast walls. These precast walls can be designed to take the appearance of concrete, wood, brick and stone. By coloring the concrete in the casting process, the concrete fence walls can take any color pattern or tint desired. Companies can also use a screening process to create any textural or design aesthetics desired as well onto the walls. Precast fence walls are also compatible with many styles and types of finishing fencing such as iron or wood. By adding an additional type of fencing material, such as iron, the appeal of the fence can be enhanced and softened and smoothed or hardened and industrialized according to taste. This flexibility to coordinate with other types of fencing also adds to the limitless décor options and visual appeal to the fence.
As well, because precast fence walls are created in varying length sections, there are many flexible options available during installation. Sections of the precast fencing can be created in varying lengths, which help customize the installation process and design of the fence to accommodate any type and variation of landscaping.
Maintenance
Precast concrete walls are designed and created in sections that range in length according to the landscape and perimeter of the land. When a section of the fence requires replacement due to damage, the replacement process is as easy as removing the section or sections with damage and replacing them. Due to the replaceable nature of this type of wall fencing, maintenance costs are minimal.
Due to the nature of the concrete materials used, precast concrete walls are a tough and sturdy fencing option. These concrete walls are able to withstand the natural elements that might deteriorate other fencing materials. The concrete materials are not susceptible to rot, wind damage, rain damage or burning as other fencing materials may be.
Security
Due to the nature and materials used in precast walls, this type of fencing is optimal when security and privacy are desired. Precast concrete wall fences range in height up to 15 feet tall which adds an additional layer of security to any fence while offering superb privacy. The thickness of the fence walls also create an added noise barrier to help reduce outside noise and quiet inside noise. In addition to being a great privacy and sound barrier, these concrete wall fences are also an excellent wind barrier. In areas of high ground wind and gusts, these fences can help reduce the low wind gusts and protect your yard and house from wind damage. Most precast concrete fence walls are reinforced with internal steel rods which add additional strength and sturdiness to the fence.
 forum activity
