Prefabricated Roof Trusses: Pros and Cons
Prefabricated roof trusses are basically part of the support system in your home. When building or remodeling your home, here are a few things that you may want to consider when it comes to prefabricated roof trusses.
Building Time
When roof trusses are used in the building process, they significantly cut down on the amount of labor and time put into the project. This is great for both the company and the consumer. Less time put into the project means less money spent for labor and parts.
Cost
Since these structures are usually made from stock, they aren't very expensive. You can also have someone less experienced install them to save even more money as they are pretty easy to do.
Variety
One of the biggest pros when it comes to prefabricated roof trusses is the variety. There is a wide variety of shapes, styles and designs for different houses and garages. This makes it easy to accommodate any project that is being done.
Durability
The biggest downside of the prefabricated roof trusses is the durability factor. While they do tend to last for a long time, there are a lot of things that can contribute to them falling apart or deteriorating like rain water, weather, animals and many other factors.
