cancel
Job type :
Zip Code :
community forums
comments
Preformed Garden Pond Liners: Pros and Cons
A preformed garden pond liner provides many advantages for an individual wishing to easily create a pond in their garden. However, there are a few disadvantages to be aware of before purchasing this liner. The pros and cons of a preformed garden pond liner are fully highlighted below to help you decide whether or not to buy this kind of liner.
Pros of the Liner
First, they are simple to use and install. Dig a hole the depth and width of the liner and then fill in with dirt around the edges. This is a much simpler process than a flexible liner, which requires you to calculate and design the size and shape yourself. Second, the construction is very durable and will last for many years. Most liners are made of sturdy plastic or fiberglass. Adversely, flexible liners are a bit flimsy and are prone to tearing. Third, if you get a hole in your preformed liner, it can be easier to spot and therefore makes repairs even easier to perform. Fourth, the liners are much easier to use for ponds above the ground. The liners eliminate the need for constructing a base for the pond as it is already included.
Cons of the Liner
The most notable con of the preformed liner is that it is not very flexible. With flexible liners, you are able to create the size and shape of pond that you desire. Another con of the liner is that they do not come in a large variety of designs and shapes. You will be limited on how creative you can be because the liners are preformed.
member comments
Related Articles
How and When to Water your Garden and LawnHow and When to Water your Garden and Lawn
Advice on how much and when you should water your garden or lawn... read more
Turning Hard Water Soft – Water Softeners
Knowing why some water is considered 'hard' while some other water is 'soft' will allow... read more
Planning and Laying Out a Low Flow Irrigation System
If you’re willing to take the time to do some up front planning you can... read more
articles we like
Making Over the Porch for Greater Curb Appeal
Making over the porch successfully can be done to suit a variety of budgets as... read more
Plywood
Plywood is a manufactured wood made to be strong and durable and commonly used in... read more
Money-making stock market secrets Money-making stock market secrets
Using short-term strategies and the right trading tools, you can take a tip from the... read more
sponsored articles of the day
diy centers
