Login Error
Close
Pressure Regulator Required for a Gas Cooktop Connection?
by DoItYourself Staff
There are a number of considerations to be given to projects involving the installation of a gas cooktop. An important consideration is whether or not a pressure regulator is required when installing this type of appliance. This has implications on the actual fitting of the cooktop as well as a series of health and safety issuesthat must be followed if the job is to be carried out safely.
Safety Regulations
It is always necessary to use a pressure regulator for a gas cooktop. The line pressure supplied from the meter will exceed the recommended pressures for cooktop use.
The hookup for this type of cooktop requires two outlets to run safely. These are the electrical outlet and the gas outlet. Hookup may need to be done by a professional depending on zoning laws.
Be sure that the cooktop itself is not placed near anything that will provide a draft, such as a window, vents or a heater.
Benefits of Fitting
Fitting personally will save money on installation costs, it is possible to install the gas cooktop and perform the required connection steps for the pressure regulator as a do-it-yourself project. It will be cheaper to do this and have the connection tested by an inspectorate of the company that is chosen to deliver the gas. The company can also provide the homeowner with a device to check for leaks at regular intervals.
Hooking up the pressure regulator is not a difficult task and will can be completed in a minimal amount of time.
 forum activity
