Login Error
Close
Proper Posture In Home Office Chairs
by DoItYourself Staff
Ergonomic method for sitting in home office chairs can ease tension while preventing backaches and other problems. We spend a lot of time in our chairs hunched over computers, gazing into flashing screens. This is a huge change from the old dimly lit office with stacks of paperwork, where there was much more movement involved. We spend less time reading paper documents, or getting up from our office chairs to retrieve files and paperwork or put them away, which means less movement and exercise.
Your work is conveineintly right in front of you on a computer screen, which causes new issues such as back pains from sitting in one spot. Sitting for long periods in home office chairs can have an effect on the curvature of your spine, and even effect your standing posture. You want a home office computer chair that is comfortable and that fits the contours of your back when sitting straight or leaning forward to work at your desk.
Posturing
One thing about home office chairs is that you can find any number of patterns and designs to assist your back while using them. However, you must be conscious of your sitting posture really matters. The comfort on your back could come from an arched support or a concave one. You want to select a chair that is the most comfortable for your back while sitting in a straight position, meaning your back straight and your shoulders back.
Most will blame a bad back on the home office chairs, when the real problem is sitting posture and not taking regular breaks to stand and move around. Sitting for long periods slouched over or dropping into your office or home office desk chairs will bring only one result, a bad back. If your posture is good and the chair does not seem to fit your body correctly, and comfortably when sitting straight, replace it immediately, before posture damage is done.
Chair Adjustments
Most of today's home office chairs have adjustable backs and sides. In many cases they be tilted back for a relaxed and casual lounging position. This is not a good idea, as your chair should be adjusted for a firm and straight back to give proper support. Your chair height should be positioned so that the arm rests are as even as possible to your desk surface to allow little stress on your arms when typing or reading paperwork.
Stretching and Hypertension Exercises
To keep yourself in good health while using home office chairs it is wise to stand and move around on a regular basis. Every hour or so, stand and do some mild in position stretches and bends. This will keep your blood flowing, as the chair can cut circulation just under your legs, causing numbness over time. Stretch your arms, and twist your wrists lightly, by spinning them around, and add in some neck and head rolls as well. You want to stay limber, and doing these short breaks with exercise will allow you to work longer, faster and without fatigue and back pains.
 forum activity
