Login Error
Close
Proper Techniques for Window Flashing Installation
by DoItYourself Staff
Installing window flashing can be done by yourself with ease, even if you have never done it before. Here are a few tips that can help you with the proper techniques for installation.
Measure Correctly
Measuring correctly can be hard if you have never done this before. When it comes to window flashing, you will need to measure both the inside and outside of the window frame to see which has the larger number. When you are cutting or deciding how much to cut of the flashing, you will need to keep in mind that the bigger number is what you want to go for. This way, you can always make the metal flashing smaller. If you don't cut enough though, you can't make it bigger, you will just have to start over instead.
Use Aluminum Nails
Using aluminum nails when you have metal flashing to put up is important for a couple of reasons. The first reason is that it holds up better and is strong for when the weather is bad. The other reason is because it looks clean and sleek when you have metal around them.
Clean Up
Cleaning beforehand is also an important technique. You want to make sure that there is no dirt or mold that can multiply.
 forum activity
