Properly Determine and Know Your Bathroom Remodeling Costs
The bathroom remodeling costs should be appropriately considered before you begin the remodel project. If you are considering remodeling your bathroom, then be sure to read the information below as to how much to spend and some basics costs of a bathroom remodel project.
Determine the Overall Cost
Before you begin your project, you should determine a reasonable amount to spend on it, which can be based on your home and its location. As a general rule, you do not want to spend more when remodeling your bathroom than you will receive if you sell your home. In fact, you should aim for at least a 200 percent return on your investment. To determine this, you must consider the size as well as the style of your home and how it compares to the homes around it.
Basic Bathroom Remodel Costs
Whether or not your remodel is extensive or simple, you will need to consider some typical and basic costs. First, the toilet and its hardware will start at $100 and only increases as the hardware becomes more intricate. Next, the flooring, if you use tile, will likely cost you $4 to $15 per square foot. Third, when updating the shower or tub area, you will most likely spend anywhere from $1500 to $7500. Fourth, replacing cabinets will require you to purchase the cabinets themselves as well as counter tops, sealant, and other applicable materials. All of these items can cost you a total of $300 to $500 or more.
