Many people think that after simply installing a home security alarm system, you can rest assured in a safe home. However, failing to properly test the system is perhaps the most important, yet most forgotten, step of installation.
Why Is Testing Important
It’s pointless to have an alarm system if it won’t work when you need it most. You need to make sure you are testing all of the windows and doors when it comes to your alarm. If you have a garage or a shed, you may want to make sure the alarm is also hooked up here as well.
False alarms are another reason to test the system periodically. Many alarm systems are designed to alert the police department or fire department when the alarm is triggered. Most counties have a policy of charging the homeowner fees for sounding false alarms. This can be a drain on your checkbook, not to mention your household and neighbors.
Sensitivity is something else that should be checked periodically with an alarm. An alarm that is overly sensitive can end up being triggered by family pets, wildlife, and even vibrations from passing cars. Not all alarms are designed to only go off when a door or window is opened or broken. Many of them also have perimeter systems that are designed to alarm when broken.
Phone lines need to be checked to ensure they are transmitting the signals to the proper authorities as well. If you have DSL or cable telephones installed you will need to check with the alarm company to ensure that the new lines are compatible with the alarm system.
Manual Test
First, set the home security alarm to the test mode that comes with the system. The manual should help you to understand how to properly do this test. This test should be done monthly.
Call Authorities About Testing
How do you know if the manual test is working? How can you be sure that the signal is getting through to the proper channels (Fire Department, Police, etc)? Instead of setting off a false alarm, call the authorities to find out if they will be notified of an emergency. This will save you from the hassle and costly fine of an accidental house call from the police.
Test the Doors and Windows
Test each and every door and window to make sure the sensors are functioning properly. While this may be time consuming, you need to trip off every sensor to make sure that the home alarm system works.
Finally, call the authorities back to make sure that your home alarm system is sending the signals back to the proper places.
These simple steps are all that’s needed to properly test a home alarm system. Many people simply take this process for granted, assuming that the installers have already done the work. After a test, you'll be able to ease your mind knowing that your home is safe and secure.
Questions of a Do It Yourself nature should be submitted to our
