Pros & Cons of a Stainless Steel Backsplash
Stainless steel backsplashes gives a touch of a modern urban chic. The following pros and cons will help you in deciding if the stainless steel backsplash is right for your kitchen or not.
Pros of a Stainless Steel Backsplash
Easy to Clean: It is one of the easiest surfaces, which can be cleaned with the help of just some hot water, soap and a sponge.
Flexible: It helps in getting blend with almost each and every color and design scheme.
Less Expensive Option: As the stainless steel backsplash is very expensive, you also have a less expensive option which would be the use of a metal laminate. It is basically a thin sheet of stainless steel, available from many manufacturers. It would hardly cost about $15 to $25 per square foot.
Cost: The cost of these stainless steel backsplash can prove to be a bit expensive, when compared to ceramic. It depends on the size, the usually cost from 50 to 250 dollars per square ft.
Scratches: The dents and the scratches are usually created on this stainless steel backsplash. Thus, do not expect it to be unspoiled.
Expenses: You would require paying a minimum of $20 per square foot, which is only for the stainless steel. The installation of this steel as well as the necessary mounting which is required can definitely increase the cost.
